It is currently Sat Jul 19, 2025 12:07 pm
PostPosted: Wed Nov 22, 2017 3:44 pm
First name: Matthew
Last Name: Whited
City: Macomb
State: IL
Zip/Postal Code: 61455
My goal originally was to strip the guitar down to the wood from a polyurethane finish and replace it with a nitrocellulose finish. However, I have had some issues removing the original finish via heat gun.
Do I remove the layer underneath the finish (I think it's a sealer coat) to get to the wood, or have I gone too far on the front?
If I have removed too much, what are possible solutions to even out the top?
I've even considered doing a wood carving in it if nothing else, so all ideas are considered.Image
Sent from my SM-G930R4 using Tapatalk
PostPosted: Wed Nov 22, 2017 4:49 pm
First name: Freeman
Last Name: Keller
(Almost) any time you do a refinish you should go to bare wood and get all of the old stuff off. There is a good chance that whatever you put on top is not going to be completely compatible with the factory finish - particularly if its a catalyzed poly. Its also usually a real hassle to get the old stuff off. I've used chemical strippers followed by a fair amount of sanding.
Generally nitro wants to be on a compatible sealer - shellac, vinyl modified sealer or sometimes just some well thinned lacquer. I'm guessing your guitar is ash or alder so it shouldn't need any pore filling
